Processors
15864 Discussions
13900KF needs your help!
koRn
您好。Hello.
我的问题是这样的。My question is this.
我的台式电脑,不定期的,在开机后,会自动进入BIOS,或进入快速启动菜单,就是让我选择启动盘。My desktop computer, from time to time, after booting up, will automatically enter the BIOS, or enter the Quick boot menu, which lets me select a boot disk.
这两种情况均在重新启动后正常进入WIN11系统。平时使用起来没有发现问题,CPUZ测试单CPU得分892.4,多核16638.7。得分来看是正常的,并且我也没有超频。Both cases enter the WIN11 system normally after restarting. Usually no problems were found in use, CPUZ test single CPU score 892.4, multi-core 16638.7. The score is normal, and I'm not overclocking.
因为找不到规律,所以我更换过这台PC的主板、内存、启动盘的SSD,可是都没有任何改变,仍然会出现这种情况。Because I could not find the rule, so I replaced the motherboard, memory, and SSD of the boot disk of this PC, but there was no change, and this situation still occurs.
但是经过观察,这种情况只会出现在关机后第二天开机,并不会出现在重新启动后。 However, after observation, this situation will only appear in the next day after the shutdown, and will not appear after the restart.
说实话,这个问题我最不该怀疑的就是CPU了吧,不过其他硬件都排除了,实在没有办法。To tell the truth, this problem I should not suspect is the CPU, but other hardware are excluded, there is no way.
请帮助我,谢谢。Please help me, thank you.
Jocelyn_Intel
Hello, @koRn
Thank you for posting on the Intel® communities.
I am sorry to hear what is happening with your PC, I will do my best to assist you here.
Was it working fine before?
Have you already contacted your Motherboard Manufacturer to check if the BIOS configuration is okay? This doesn't seem to be a processor issue, it might be related to the BIOS configuration or the way that is booting up.
You mentioned that you replaced the motherboard. What is the model of the second motherboard? Is it the same model as the original?
Jocelyn M.
Jocelyn_Intel
Hello, @koRn
I hope you are great.
I am checking this thread and I would like to know if you were able to check my previous post.
Jocelyn M.
Jocelyn_Intel
Hello, @koRn
I hope you are doing great.
As we have not heard back from you, we will proceed to close this thread now.
If you need any further assistance, please feel free to contact us back and submit a new question as this thread will no longer be monitored.
Jocelyn M.
