Processors
14820 Discussions
13th Gen Intel® Core™ i9-13900H Processor very low frequency 390-436 MHz
Oleksandr_Osad123
Unfortunately, I encountered such a problem as low performance and the reason for this was the low processor frequency (14 cores and 20 threads). When powered by battery, then 390 MHz, and when from the network, then 436 MHz.
Rebooting did not solve the problem, and the diagnostics did not find anything. Restoring the system to factory settings via cloud storage initially solved the problem, so it seemed. But after a night in the off state, when turned on, the problem returned again and so far no change.
Oleksandr_Osad123
Finally found the reason of CPU low frequency. Looks like this is a failsafe mode in case there is something wrong with the CPU cooling fan. Today after having started the diagnostic procedure for cooling fans again and noted that GPU fan speed reached max 7200 rpm while CPU fan - only  3000 rpm and thereby the problem with the fan has been reported. However, this diagnostic test was passed before few times without any problem detected. May be this info will be usefull for somebody.
On Monday I will contact service center and will see what they advise.
AlfredoS_Intel
Hi Oleksandr_osad123,
Thank you for sharing your brilliant fix for your concern.
I am sure that this would be useful if other members using the same configuration as you experienced the problem.
We will be closing this thread since your concern is already resolved. If you would like to give us an update or if you have further questions, please submit a new question as this thread will no longer being monitored.
Thank you for contacting Intel® and have a great week!
Alfred S
