Hello Chrysanthos,
Thank you for posting in the communities. I noticed you are using liquid cooling solution; are the pump cable and radiator fans plugged into appropriate board headers? The reason I ask is because if this is a newly built system and you are experiencing overheating, it is best to double check the cooling solution so we can determine if there is an issue with the hardware. Also, may I please know the list of games that crash for you? Does your system randomly shut down when this occurs and take some time before booting up? Are there also any error messages showing up when this issue occurs? This will help us determine the cause of the temperature spike faster. I will be waiting for your reply.
Ramyer M.
Hello Chrysanthos,
How is your system doing? I am just checking in about the questions I have asked in my previous post. Feel free to share it with us so we can better assist you. I will be waiting for your reply.
Ramyer M.
Hello Chrysanthos,
I hope you are doing well. As we have not heard a response in the past few days, we will proceed in closing this thread. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Ramyer M.
