Processors
16132 Discussions
19-13700k
Chris41
I’m just trying to find some information on if the artic liquid freezer II 280m will be enough to keep this cpu cool or if I need something stronger
What I’ll be using if it matters or will help determine things
Intel core i9-13700k
ARCTIC Liquid Freezer II 280 A-RGB 68.9 CFM Liquid CPU
Z790 AORUS ELITE AX ATX LGA1700 Motherboard
G.Skill Ripjaws S5 64 GB (2 x 32 GB) DDR5-5600 CL28 Memory
OC Radeon RX 7800 XT 16 GB
Corsair RM850e (2023) Fully Modular 850w 80+ gold
4 be quiet! Silent Wings Pro 4 120mm PWM 3000 RPM case fans
Fractal Design Pop XL Case
AlfredoS_Intel
Hi Chris41,
Thank you for creating a thread to confirm if the fan that you have is adequate to cool your processor in Intel Communities.
To know if a certain thermal solution is adequate, you just need to confirm if the cooling solution is compatible with the processor’s supported socket and motherboard and the fan supports higher than 125 W, which is the processor’s base power. We tried to look it up on your fan’s product description site; however, we are unable to do so, so it would be best if you reach out to your liquid cooler’s support team to more accurate information.
For reference, you can consult this article, How to Choose Thermal Solutions for Intel® Core™ Boxed Desktop Processor.
We hope that you find the above post helpful.
Alfred S
AlfredoS_Intel
Hi Chris41,
We are just following up.
It looks like you need more time to assess the answers that we have provided.
Alfred S
AlfredoS_Intel
Hi Chris41,
We need to close this thread since we have not gotten a response from you: maybe because you are busy or preoccupied at the moment.
We hope that our suggestion for you to coordinate with the manufacturer of the fan to get the specifications helped you confirm the answer to your question.
We were waiting for your feedback since it is important for us to give you the right solution on your concern.
As much as we would like to continue assisting you, we need to close it to avoid overwhelming your inbox with notifications.
We hope for your consideration and understanding on this one.
If you need any additional information, please submit a new question as this thread will no longer being monitored.
Thank you for contacting Intel® and have a great week!
Alfred S
