So I have Intel I5-6402p which is a bit old but never was overclocked and should be still fine.
But when I enable 3/4 cores the PC starts randomly restarts (I got BSOD's before but at some point it just started to restart)
As of now the PC can operate normaly at 2 cores only.
I was trying to solve this issue on other forums but nothing really helped.
The only things that I know are that when I was getting still BSOD's it was "IRQL_NOT_LESS_OR_EQUAL" And in Event Viewer I was getting critical error "kernel-power 41 (63)" Thats when the forums told me to buy new PSU because its probably faulty. I did as they said I bought new PSU (600W), and replaced a lot of components for a new ones. But the problem is still here.
Is there any way it could be somehow solved ? Or the CPU has just broken 2 cores ?
Thank you.
My specs:
CPU: Intel I5-6402p
GPU: AREZ-DUAL-RX580-8G
RAM: HyperX 16GB KIT 2400MHz DDR4 CL12 Predator
Mobo: Gigabyte H110-D3A
PSU: Cooler Master Elite V3 600W
Storage: 250GB SSD, 2x 1TB HDD
Bad memory?
It is certainly not a common occurrence, but I have seen this happen once or twice before (though usually a single core, not two).
I am unsure memory could be culprit, but run some tests anyway. Run tests with only single DIMM installed; try it in each DIMM slot.
Hope this helps,
