Processors
14539 Discussions
2x E5-2696v2 on a platform build with S2600CP or CP4
jps
I went accross 2x E5-2696v2 processors and tried to use them in one of our work stations based on S2600CP or S2600CP4 motherboards. Unfortunately neither of the computers worked with those CPU's. Both of the computers worked fine with 2690 v1 and 2667w v2 though. So my question is if the two processors should work with those two platforms? Any help would be much appreciated.
regards
janusz
jps
Maybe more specific information will be helpfull to solve my problem:
Chipset: Intel C602 rev. 06
Mainboard Model: S2600CP (0x000001AE - 0x005368B0)
revision: E99552-510
serial: QSCP34300402
BIOS: SE5C600.86B.02.02.0002.122320131210 dated at 12/23/2013
where minimum required bios is ver. 02.01.0002 from 09/07/2013
the list of compatible processors is: http://www.intel.com/support/motherboards/server/sb/CS-033241.htm http://www.intel.com/support/motherboards/server/sb/CS-033241.htm
where 2696v2 does no appear.
looking forward your help.
regards
Janusz
Allan_J_Intel1
If the processor compatibility list does not show your processor model, it has not been officially tested. I would recommend contacting the server team to see if there is a BIOS (microcode) update you can get for your motherboard model.
Allan.
jps
regards
Janusz
Allan_J_Intel1
Allan.
