Hello i've been using my 4790k for 3 years and never had a problem with temps as i'm using the Corsair H100i v2 watercooler and temps were always fine.However 4 days now the core 0 will go up to 95-100 degress and the rest of the cores will remain at 75-80.I've tried resitting my cpu cooler several times and also im running on stock 4.0 ghz with 1.13v which is considerably low.What could be wrong?
Hello reckz93,
I would like to gather more information regarding your situation and your system configuration, so please respond and provide the following information:
To attach a file, you must click "Use Advanced Editor" in the top right corner of the response box, then the "attach" option will appear in the bottom right corner of the response box.
Amy C.
reckz93, if you need further assistance let us know.
Amy C.
