Processors
14539 Discussions
7700hq Slow on battery at 800MHz
MCout4
When I run the laptop pluged in, it's all fine. CPU base Freq is 2.8GHz but manages to stay around 3.50GHz.
When I unplug the power, the fun starts. I mean stops. It would drop to 1.5GHz then 800Mhz and stay there as long as I have a little load. Exemple, if nothing is running, it will go back to 1.5 ish but as soon as I start something, Chrome for exemple, it goes down to 800MHz. It is so slow that you can't even watch a Youtube video. At 800MHz, the CPU load in task manager refuse to go above 20% or so I think.
I tried disabling Intel Speedstep, update all drivers, play with minimum CPU freq. in power management, reinstall Windows from scratch I even unplugged the battery for a while as suggested in another post. Disabling the dGPU... No luck.
The computer is almost unusable on battery.
Intel Extreme tuning utility reports constant Power Limit Throttling on battery.
I have the i7 7700hq model, Dell inspiron 7757. Windows 10. I know this CPU is power hungry but I am suspecting a setting that is wrong. I would gladely accept a speed reduction, but at least to be able to surf the web or watch a Youtube movie.
n_scott_pearson
My gut is saying look for errors in the BIOS Configuration. I would first try setting it back to defaults and see if that frees it up.
