Community
cancel
Showing results for
Search instead for
Did you mean:
DFryh
7820x running at 1.2ghz, Please help
I just built a new 7820x system, CPU z and Intel ETU both show it running at 1.2GHz even when stress testing. I do see Current Limit Throttling flash yes when benchmarking or stress testing with ETU. This is much worse than my 4770k that I upgraded from. CPU is running at 25c.
I don't know a lot about overclocking, using ETU, I adjusted the core ratio to 36 and it's still stuck on 1.2GHz, even under stress test or benchmark.
My specs:
Corsair 750w PS
Corsair Hydro H100i v2
MSI x299 Raider
G.skill ripjaw DDR4 3200
Asus GTX1080
Community Manager
Hello ry737
Thank you for joining the community.
Is the BIOS of the motherboard updated?
Allowed to share with you the following link form the manufacturer for the BIOS download versions.
https://www.msi.com/Motherboard/support/X299-RAIDER https://www.msi.com/Motherboard/support/X299-RAIDER
Please be aware that the content on that site is not controlled by Intel®. This information is offered for your convenience and should not be viewed as an endorsement by Intel® for the merchants or services offered there.
Leonardo C.
DFryh
Yes, I'm running BIOS version 1.70 which is the most current.
Community Manager
Hello Fry737
Thank you for your response.
Could you help us with the following troubleshooting steps?
  1. Enter the BIOS (motherboard F1/F2/Delete Key, etc.). Load the default BIOS settings (most likely with F9 key), and disable all the auto-tuning features of your motherboard if available.
  2. Run the same test you mentioned in the original post, plus the Intel® Processor Diagnostic Tool available at the following link (please attach the results). https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool
  3. Restart the System and enter the BIOS again, look for the processor>multi core processing (option/tab/section – depends on your motherboard) and enable the single core option.
  4. Repeat step 2.
  5. Provide us with all the reports and if possible screenshots/pictures of the BIOS settings, and info related to the processor (frequency, options, etc. BIOS).
Leonardo C.
DFryh
replaced motherboard and power supply, CPU now running very stable at 4.3MHz and 45c.
