Hello @Aarambh
We understand your concern about the base frequency of your Intel® Core™ i5-8400 Processor, we will be more than happy to give you some information.
Please keep in mind that the performance is managed by the operating system, depending on the workload. The processor won’t be always at the base frequency or Max Turbo Frequency.
Our recommendation is to have your system up to date. Please go to select Start > Settings > Windows Update.
Another recommendation is to update the BIOS (for further assistance, please contact the system manufacturer).
Also, in order to have more information about your system, please download, install and run Intel® System Support Utility for Windows. Make sure you check “Everything” before you scan, then save the report and attach it to your response.
Jose B.
Hello Aarambh,
I am following up because I want to know if your issue with a low frequency persists. Let me know if you need further support.
Deivid A.
Hello Aarambh,
I was checking your thread and noticed that I have not heard back from you. I’m going to close your post, but if you need further assistance, please do not hesitate to create a new thread.
Deivid A.
