Community
cancel
Showing results for
Search instead for
Did you mean:
Savage2001
9600k Underperforming
Hello so my performance on games has gotten low a lot ever since I switched cooler, I had the same cooler but I switched it to one that has rgb same one hyper 212 rgb cooler and before it performed very good, but a week later when I switched it, it started being so slow at first it would't go past 4.3 ghz and I have overclock on and its at 5.12 ghz but it still feels very very slow If you can help me fix that and I ran a cpu stress test with thermal boost on and per core on and these are the results.
Alberto_R_Intel1
Savage2001, Thank you for posting in the Intel® Communities Support.
In reference to this scenario, you mentioned "performance on games has gotten low a lot ever since I switched cooler", just to confirm:
How are you detecting/monitoring that the performance of the games is not the same?
Which aspects have gotten slower?
Is it happening with all the games or just with a specific game?
In order to make sure and rule out a possible hardware problem with the Intel® Processor, we can try the following:
-Please get into the BIOS of the board and reset all the values to defaults
-Disable any Overclocking option or feature
-Disable XMP profiles on memory RAM
After that, please run the Intel® Processor Diagnostics Tool, it does an overall test on the unit and if it passed the test it means that it is working properly:
https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool?wapkw=ipdt
In order to monitor the temperature on the system, please install the Intel® Extreme Tuning Utility, it will provide a real-time temperature value so we can discard an overheating problem:
https://downloadcenter.intel.com/download/29183/Intel-Extreme-Tuning-Utility-Intel-XTU-
If the problem persists after that, please provide the SSU report so we can verify further details about the components in your platform, please check all the options in the report including the one that says "3rd party software logs":
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91...
Albert R.
Alberto_R_Intel1
Hello Savage2001, I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Albert R.
Alberto_R_Intel1
Hello Savage2001, Since I have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
