I have an impression that exact specs of Core 4700MQ, 4800MQ and 4900MQ on ark.intel.com may be not 100% correct. There, the info on max HDMI and VGA resolutions is as follows:
4700MQ: 3840x2160@60fps (HDMI), 2880x1800@60fps (VGA)
4800MQ: 2560x1600@60fps (HDMI), 1920x1200@60fps (VGA)
4900MQ: 3840x2160@60fps (HDMI), 2880x1800@60fps (VGA)
so 4800MQ has the weakest scores despite that its integrated GPU is exactly as in 4900MQ. Thus the question is: is there a typo on ark.intel.com or are there actual differences between max resolution of these CPUs?
Hello GregoryD,
Thank you for joining the Intel Community Support.
Thank you for providing us with your valuable feedback. There is a typing error on ark.intel.com. The case has been escalated to the proper department.
Keep checking https://ark.intel.com/ to get up to date information about our product specifications.
Wanner G.
Hello GregoryD,
Wanner G.
Hello GregoryD,
In addition, the most common resolution over VGA-flat panel is 1920x1080 @60Hz. However, it might change depending on the screen designed by the manufacturer.
Maximum Resolution (VGA) is the maximum resolution supported by the processor via the VGA interface (24bits per pixel & 60Hz). In the case of the processors mentioned before, the system (laptop/NUC, etc.) or device display resolution is dependent on multiple system design factors, and the actual resolution indicated in Ark.intel.com may be lower on your system.
Wanner G.
Hello regoryD,
I was checking this thread and I would like to add that the information on https://ark.intel.com/ is correct. Monitors should be capable of supporting a specific resolution (LCD/LED with VGA). Also, system manufacturers may or may not limit the resolution or features when processors are integrated on a laptop.
Wanner G.
