Boa noite
Estou criando esse tópico para entender melhor a respeito do RMA da intel.
Estou pensando em adquirir um processador da Intel para Games, porém vem uma questão importante a respeito das memórias ao qual irei utilizar, estou pensando em utilizar memória 3200 mhz, a Intel utiliza um programa chamado XMP que serve para aumentar a frequência da memória, gostaria de saber se eu realmente posso aumentar a frequência da memória sem que isso acabe interferindo na garantia do produto.
Caso o processador venha a apresentar defeitos pelo uso do XMP eu terei Reembolso ou a troca?
Grato
You need to contact your laptop or system/motherboard manufacturer for these questions.
Doc
Hello @Al.Hill
Proc: Intel Core i7-9700K Coffee Lake, Cache 12MB, 3.0GHz (4.7GHz Max Turbo), LGA 1151
Motherboard : Gigabyte Z390 Aorus Pro, Intel LGA 1151, ATX, DDR4
Memory: HyperX Predator RGB, 16GB (2x8GB), 3200MHz, DDR4, CL16, Preto - HX432C16PB3AK2/16
SSD HyperX Fury RGB, 480GB, SATA, 550MB/s, 480MB/s - SHFR200/480GB
Seasonic Platinum 660W 80 Plus Platinum - Full Modular
You need to ask gigabyte about what their motherboard will support.
Doc
This MotherBoard
• Support DDR4 4266 (OC) / 4133 (OC) / 4000 (OC) / 3866 (OC) / 3800 (OC) / 3733 (OC) / 3666 (OC) / 3600 (OC) / 3466 (OC) / 3400 ( OC) / 3333 (OC) / 3300 (OC) / 3200 (OC) / 3000 (OC) / 2800 (OC) / 2666/2400 /
• Dual Channel DDR4, 4 DIMMs with Ultra Durable Memory Armor
• XMP Support
"Altering clock frequency or voltage may damage or reduce the useful life of the processor and other system components, and may reduce system stability and performance. Product warranties may not apply if the processor is operated beyond its specifications. Check with the manufacturers of system and components for additional details. "
"Enabling and use of Intel® XMP is a type of overclocking, and will ultimately void the CPU warranty. Altering clock frequency or voltage may damage or reduce the useful life of the processor and other system components, and may reduce system stability and performance. Product warranties may not apply if the processor is operated beyond its specifications. Check with the manufacturers of system and components for additional details."
Doc
