Since I built my PC I didn´t realized why my cpu core temps are much lower than the package temps. Why is that? Also when I run Cinebench R15 with my i7-4790K at 4Ghz the temps are perfectly fine 66-70º at 1.064v, but when I run it at 4,4Ghz at 1,987v (set by the TB) my processor goes up to 82º. I´m on watercooling (h100i GTX)
I have checked your post and the processor temperatures do not appear to be causing any problem since the maximum processor temperature is 74.04°C, this will increase if the processor is running with turbo boost. As long as the computer won't shutdown by itself you are fine.
You will find some troubleshooting tips that may help prevent overheating issues:
http://www.intel.com/content/www/us/en/support/processors/000005776.html http://www.intel.com/content/www/us/en/support/processors/000005776.html
Allan.
But 82-83 degree at nearly 1,2v at 4,4GHz (Stock) If that means the proccesor will go at 105 degree at 4,8Ghz at 1,32v. I swear is the thermal paste. I need to change it (after 7 months)
You can request more thermal material by calling North America Customer Support Center Phone Number: 1-916-377-7000Business Hours:
Monday - Friday
7:00 AM to 5:00 PM (Pacific Time)
For more contact information try this link:
http://www.intel.com/content/www/us/en/support/contact-support.html# @12 http://www.intel.com/content/www/us/en/support/contact-support.html# @12
Allan.
Thermal paste will only give you 1-2c difference if applied wrong also it last forever. I would check your h100i GTX, case fans, is the radiator getting warm, radiator fans.
May be the radiator, because my house actually has dust and the 350D doesn't come with a top filter mesh. But that dust can affect that much the performance of the radiator?
No the dust should not do a thing your radiator would get hot. Check your pump hoses for temperature.
