Processors
14513 Discussions
Activate TPM 2.0 - Intel Core i9-9900X
JVP
Hello.
I have Intel Core i9-9900X processor and want to enable TPM 2.0 to prepare my PC for Windows 11.
I have to start by saying that I am a PC amateur and am terrified to do something wrong in BIOS.
After searching the web, the tip was to go into BIOS / Advanced / PCH-FW Configuration/PTT Configuration and set PTT to Enabled - which should solve the problem.
But despite this, I get a message that TPM 2.0 is not installed when I run Microsoft PC Health Check or the command "tpm.msc".
I get the following message:
• TPM can not be used. PCR7 binding is not supported.
• The hardware security test interface failed.
• The device is not in modern standby mode.
• Not allowed bus / unit (s) with DMA function detected.
Hope someone can help a PC amateur to solve the problem.
Jan
AlHill
contact your motherboard manufacturer about updating their bios for TPM/PTT support.
