Processors
Processors (Intel® Core™, Intel® Xeon®, etc); processor utilities and programs (Intel® Processor Identification Utility, Intel® Extreme Tuning Utility, Intel® Easy Streaming Wizard, etc.)
12912 Discussions
After updating to Windows 10 - Intel (R) 7 Series / C216 Chipset Family
ElluK
Acer Aspire V5-572P_0798_2_09
BIOS Version / Date Insyde Corp. V2.09, 05/09/2013 (I haven't upgraded to version 2.1 from Acer)
SMBIOS Version: 2.7 BIOS model UEFI
Baseboard manufacturer Acer
base plate product Dazzle_CX
baseboard version Type2 - A01 Board Version
Processor: Intel (R) Pentium (R) CPU 2117U @ 1.80GHz, GenuineIntel
Intel64 Family 6 Model 58 Stepping 9
Operating system: Microsoft Windows 10 Home Version 10.0.19044 Build 19044
System type: x64-based PC
After updating to Windows 10, the following message came.
Event Viewer (Local) - Saved Logs - Microsoft-Windows-BitLockre% 4BitLocker Management
Devices that support DMA (direct memory access) have not been reported to be protected from external access. which can prevent security features such as BitLocker automatic device encryption
ISA Bridge:
PCI \ VEN_8086 & DEV_1E57 (Intel (R) HM77 Express Chipset LPC Controller - 1E57)
PCI-to-PCI Bridge:
PCI \ VEN_8086 & DEV_1E14 (Intel (R) 7 Series / C216 Chipset Family PCI Express Root Port 3 - 1E14)
PCI \ VEN_8086 & DEV_1E12 (Intel (R) 7 Series / C216 Chipset Family PCI Express Root Port 2 - 1E12)
PCI \ VEN_8086 & DEV_1E10 (Intel (R) 7 Series / C216 Chipset Family PCI Express Root Port 1 - 1E10)
When I upgrade with Intel Driver & Support Assistant Up to date, everything is fine,
but it does not update the Intel (R) 7 series / C216 Chipset Family through it and I do not find any updates on the Intel website. Is the Intel (R) 7 series / C216 Chipset Family discontinued? Is there a security risk if this is not updated anymore?
I have these listed below on my machine. Where can I check to see if I have the latest drivers?
And is there any security risk if the part has been discontinued i.e. is apparently no longer being updated? Can these discontinued ones be replaced / upgraded with another valid one? I try to keep the security of my machine as good as possible, as the intention is to use the machine as long as WIN10 is valid, ie on October 14, 2025, because the Pentium 2117U is not compatible with WIN11. And if I understand anything, this part can't be replaced with a laptop.
If the BIOS is from Intel, can it be updated somehow through Intel and will it improve any situation
or will it become a compatibility issue with the Acer system? Does the BIOS 2.1 update on the Acer website help with these issues.
IDE ATA or ATAPI drivers
Intel (R) 7 Series Chipset Family SATA AHCI Controller
Driver dated 18.3.2013
Driver version: 12.5.0.1066
There will be a yellow triangle in Device Manager, meaning action is required but does not indicate what.
System equipment
DMA controller
Manufacturer: (Standard system equipment)
Location: in Intel (R) HM77 Express Chipset LPC Controller - 1E57
No driver is installed for this device.
Driver dated 21.6.2006
Driver Version: 10.0.19041.1202 (Microsoft)
The date of the driver is October 3, 2016
Driver Version: 10.1.1.38
Event Monitor reports the error described above.
Event Monitor reports an error, but Intel's website says it launched.
Intel (R) Management Engine Interface
Driver dated 7.7.2015
Driver version: 11.0.0.1157
Xeon (R) processor E3 - 1200 v2 / 3rd Gen Core processor DRAM Controller - 0154
As far as I know, this has ended on 1.6.2020.
Video adapters
Intel (R) HD Graphics
Driver Date 6.8.2020
Driver version: 10.18.10.5161
There will be a yellow triangle in Device Manager, meaning action is required but does not indicate what. However, Windows Security reports incompatible drivers so it causes security problems, i.e. whether there would be a change in WIN10 behind this as well. I downloaded the Intel Pentium Processor 2117U compatible version 15.33.53.5161 from the Intel website date 23.10.2020,
but the yellow triangle is still.
Processors
Driver dated April 21, 2009
Driver version: 10.0.19041.546
To my knowledge, this has been discontinued at 12,2020, but according to Intel's pages
supports WIN10 version 21H2 which i have.
USB drivers
Intel (R) 7 Series / C216 Chipset Family USB Enhanced Host Controller - 1E2D
The date of the driver is 5.10.2012
Driver version: 9.3.0.1025
Intel (R) 7 Series / C216 Chipset Family USB Enhanced Host Controller - 1E26
Intel (R) USB 3.0 eXtensible Host Controller - 1.0 (Microsoft)
Driver Date 10.2.2022
Driver version: 10.0.19041.1566
I thought this was stopped too, but then it upgraded to a really fresh version.
Audio, video and game controllers
Intel (R) display audio
Driver dated 9/9/2014
Driver version: 6.16.03154
AlHill
Your processor is not supported by Windows 10:
https://docs.microsoft.com/en-us/windows-hardware/design/minimum/supported/windows-10-21h2-supported...
Sorry, but it is time for you to get a new or newer system.  I suggest you look at something with an 8th gen or greater processor.
By the way, your processor is from 2012.
https://ark.intel.com/content/www/us/en/ark/products/71469/intel-pentium-processor-2117u-2m-cache-1-...
[Waiting for Windows 12]
OnoCla
I have a Laptop Acer Aspire V3-571G, with i7-3632QM, with Windows 10 32 bit on a partiton of HD-ssd and Windows 64 bit  on another partition of the same HD-ssd and they work fine.
You can update driver with free software (i.e. : driver booster).
AlHill
@OnoCla Your processor is not supported by Windows 10:
Please do yourself a favor and NOT use 3rd party driver sites like driver booster.  You never know what information from your machine they are uploading (and to what country it is going), and you never know what payload is in the packages they are downloading.
OnoCla
Concordo con te che è meglio non usare terze parti per driver, infatti anche INTEL fornisce check dei driver.
Proprio oggi driver-booster mi ha creato un guaio, ma ho usato il punto di ripristino e tuto è andato e ritornato bene.
Comunque, confermo che WINDOWS 10 32bit funziona bene su ACER ASPIRE V3-571G con i7-3232QM.
Saluti
