Processors
Processors (Intel® Core™, Intel® Xeon®, etc); processor utilities and programs (Intel® Processor Identification Utility, Intel® Extreme Tuning Utility, Intel® Easy Streaming Wizard, etc.)
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11682 Discussions
Any tool (like CHIPSEC) to verify the security of Intel XEON Skylake platform?
SHebe1
I wanted to try the tool "chipsec" on an Intel Purley platform (XEON 8176 and Lewisburg PCH).
Note: the chipsec tool is mentioned in Intel doc # 557274 Platform Secure Configuration Specification for Skylake Platforms.
Description of the tool:
CHIPSEC is a framework for analyzing the security of PC platforms including hardware, system firmware (BIOS/UEFI), and platform components. It includes a security test suite, tools for accessing various low level interfaces, and forensic capabilities. It can be run on Windows, Linux, Mac OS X and UEFI shell.
The tool is available from: https://github.com/chipsec/chipsec.git
The tool detects several Intel CPU+PCH chipset combinations, but not the Skylake Server or PCH Lewisburg.
Information about the CPU: Intel® Xeon® Platinum 8176 Processor (38.5M Cache, 2.10 GHz) Product Specifications
CPU stepping used: H0
The PCH used: Lewisburg 1G, stepping B1
EDS: Intel® C620 Series Chipset Platform Controller Hub, Document Number: 547817
Is there any plan to add support for this non-embedded platform into ChipSec?
Or is there any other tool that perform the same kind of security verification?
Community Manager
Hello SHebert_KCI
Thank you for joining the community.
I see that you are looking for a software/tool to analyze the security of your PC, allow me to share with you that for the information you are looking we recommend you to present your inquiry in the Intel® Embedded Community, please refer to the following link:
https://embedded.communities.intel.com/select-display-name!input.jspa https://embedded.communities.intel.com/select-display-name!input.jspa
Thank you.
Leonardo C.
Community Manager
Hello SHebert_KCI
Thank you.
Leonardo C.
