Hello, Akhmedbekov. Thank you very much for sharing your issue with the Intel Communities Team. I will be more than glad to assist you.
In this case, there is no way to get these capacitors and, it will not be possible to install once it is missing. If you received this product in this way and the unit is still under its warranty period, you can always get in touch with the vendor or you can reach https://www.intel.com/content/www/us/en/support.html Intel® Support for a replacement.
Antony S.
Antony S.
