Processors
13568 Discussions
Assignment of mainboard components is corrupted after try to boot a SSD without Uefi partition
ber999
I have investigated the issue further and finally found out that the UEFI Firmware is preventing not only the use of other than HP distributed NVMe SSDs but every NVMe SSD in the slot affected.
The initiating incident was that had replaced the original SSD in the slot by a cloned SSD with larger capacity on which unfortunately the Efi partition was missing and then tried to boot the notebook and got an error message due to the situation.
After that, every attempt to boot the notebook from a SSD in the slot in question failed with the same error message.
Consequently, I have installed the Windows 10 system on the existing HDD in the SATA port, which brought serious performances losses.
Nevertheless, the investigation of the machine revealed that the Uefi hardware initialization which runs at the beginning of the boot process does not assign the NVMe SSD to the correct bus position PCI Express x8 Bus #1 [J6B2], because the Graphics card NVIDIA GeForce GTX 1050 Ti [HP] is assigned th this bus position now (see below).
For the Graphics card NVIDIA GeForce GTX 1050 Ti [HP] is the PCI Express x16 slot appropriate because of is matching width (x16 and not x8).
As the Uefi hardware-initialization-procedure does not assign the NVMe SSD now, the NVMe SSD hardware cannot be found by any operating system.
The Hwinfo64 report delivers the following results for my HP Pavilion:
  1. in the motherboard section
Motherboard Slots:
2xPCI Express x1, 1xPCI Express x8, 1xPCI Express x16
  1. in the bus section
[General Information]
Device Name:
Original Device Name:
NVIDIA GeForce GTX 1050 Ti (GP107M)
Device Class:
VGA Compatible Adapter
Revision ID:
A1
PCI Address (Bus: Device:
Function) Number:
1:0:0
PCI Latency Timer:
0
Hardware ID:
PCI\VEN_10DE&DEV_1C8C&SUBSYS_84ED103C&REV_A1
[PCI Express]
Version:
3.0
Maximum Link Width:
16x
Current Link Width:
8x
Maximum Link Speed:
8.0 GT/s
Current Link Speed:
2.5 GT/s
Device/Port Type:
PCI Express Endpoint
Slot Implemented:
No
Emergency Power Reduction:
Not Supported
Active State Power Management (ASPM) Support:
L0s and L1
Active State Power Management (ASPM) Status:
L0s and L1 Entry
L0s Exit Latency:
256 - 512 ns
L1 Exit Latency:
2 - 4 us
Maximum Payload Size Supported:
256 bytes
Maximum Payload Size:
256 bytes
Resizable BAR Support:
Not Supported
[System Resources]
Interrupt Line:
N/A
Interrupt Pin:
INTA#
Memory Base Address 0
63000000
Memory Base Address 1
50000000
Memory Base Address 3
60000000
I/O Base Address 5
0
[Features]
Bus Mastering:
Enabled
Running At 66 MHz:
Not Capable
Fast Back-to-Back Transactions:
Not Capable
[Driver Information]
Driver Manufacturer:
NVIDIA
Driver Description:
Driver Provider:
NVIDIA
Driver Version:
27.21.14.6627 (GeForce 466.27)
Driver Date:
23-Apr-2021
DCH/UWD Driver:
Capable
DeviceInstanceId
PCI\VEN_10DE&DEV_1C8C&SUBSYS_84ED103C&REV_A1\4&33ECA368&0&0008
Location Paths
PCIROOT(0)#PCI(0100)#PCI(0000)
The PCI Express bus enumeration ends with #3 and the NVMe PCIe SSD controller is not listed.
However, a Hwinfo64 report of a comparable board can be found on the Internet.
There, an NVMe PCIe SSD controller is listed in the Bus section (see below) under PCI Express x4.
PCI Express x4 Bus #4
Samsung NVMe PCIe SSD Controller
Device Name:
Samsung Electronics NVMe PCIe SSD Controller
Device Class:
NVMe Controller
Revision ID:
0
PCI Address (Bus: Device: Function) Number:
4:0:0
PCI Latency Timer:
0
Hardware ID:
PCI\VEN_144D&DEV_A808&SUBSYS_A801144D&REV_00
[PCI Express]
Version:
3.0
Maximum Link Width:
4x
Current Link Width:
4x
Maximum Link Speed:
8.0 GT/s
Current Link Speed:
8.0 GT/s
Device/Port Type:
Slot Implemented:
No
Not Supported
L1
L1 Entry
L0s Exit Latency:
>4 us
L1 Exit Latency:
32 - 64 us
256 bytes
256 bytes
[System Resources]
Interrupt Line:
N/A
Interrupt Pin:
INTA#
AD200000
[Features]
Bus Mastering:
Enabled
Running At 66 MHz:
Not Capable
Not Capable
Standard NVM Express Controller
Driver Description:
Driver Provider:
Microsoft
Driver Version:
10.0.19041.488
Driver Date:
21-Jun-2006
DeviceInstanceId
PCI\VEN_144D&DEV_A808&SUBSYS_A801144D&REV_00\4&CDF9F35&0&00DC
Location Paths
PCIROOT(0)#PCI(1B04)#PCI(0000)
My HP Pavilion, on the other hand, does not have a PCI Express x4 slot, but it does have a PCI Express x8 slot. According to the Hwinfo64 report of my HP Pavilion notebook, the graphics card NVIDIA GeForce GTX 1050 Ti (GP107M) sits in the PCI Express x8 slot. Specified for this graphics card is x4.
Maximum Link Width:
16x
In the Hwinfo64 report of the board used for comparison, the graphics card is attached to the PCI Express x16 bus #1 (see below) as listed in the Bus section, i.e. in the correct place (16 lanes).
PCI Express x16 Bus #1
NVIDIA GeForce GTX 1060 [GIGABYTE]
Device Name:
NVIDIA GeForce GTX 1060 (GP106M/N17P-G1)
Device Class:
Revision ID:
A1
PCI Address (Bus:Device:Function) Number:
1:0:0
PCI Latency Timer:
0
Hardware ID:
PCI\VEN_10DE&DEV_1C20&SUBSYS_16521458&REV_A1
Version:
3.0
Maximum Link Width:
16x
Current Link Width:
16x
Maximum Link Speed:
8.0 GT/s
Current Link Speed:
2.5 GT/s
Device/Port Type:
Slot Implemented:
No
Not Supported
L0s and L1
L0s and L1 Entry
L0s Exit Latency:
256 - 512 ns
L1 Exit Latency:
8 - 16 us
256 bytes
256 bytes
[System Resources]
Interrupt Line:
N/A
Interrupt Pin:
INTA#
AC000000
80000000
90000000
I/O Base Address 5
0
[Features]
Bus Mastering:
Enabled
Running At 66 MHz:
Not Capable
Not Capable
NVIDIA
Driver Description:
Driver Provider:
NVIDIA
Driver Version:
27.21.14.5167 (GeForce 451.67)
Driver Date:
05-Jul-2020
DCH/UWD Driver:
Capable
DeviceInstanceId
PCI\VEN_10DE&DEV_1C20&SUBSYS_16521458&REV_A1\4&DAED9F9&0&0008
Location Paths
In the System Buses section of the SiSoft Sandra report of my Pavilion notebook (see below), there is a warning 1204 at the end. Possibly, the reference there to the higher maximum supported speed is due to the lower number of lanes (8 in the bus instead of 16).
SiSoftware Sandra Systembusse
Systembusse
Schnittstellenversion: 2.30
PCI Busse: 4
PCIe Busse: 3
Systembus
Typ: PCI
Gerätenummer: 0
Multiplikator: 1x
Systembus
Typ: PCIe 3.0 x8 2.5Gbps
Gerätenummer: 1
Multiplikator: 3x
Bridge: Intel Core6 (Skylake) PCIe Controller (x16)
Systembus
Typ: PCIe 3.0 x1 2.5Gbps
Gerätenummer: 2
Multiplikator: 3x
Bridge: Intel ICH300 (Cannon Point) PCI Express Root Port #14
Gerät mit Anschluss verbunden: HP RTL8168/8111 PCI-E Gigabit Ethernet NIC
Systembus
Gerätenummer: 3
Multiplikator: 3x
Bridge: Intel ICH300 (Cannon Point) PCI Express Root Port #16
Gerät mit Anschluss verbunden: HP RTS522A PCI Express Card Reader
Leistungstipps
Warning 1204: Speed is below the maximum supported speed. The device may be in power-saving mode.
Tip 3: Press Enter or double-click on a tip to find out more information.
As the NVIDIA graphics card is soldered directly on the motherboard, there is, for test purposes, no possibility to disconnect the NVIDIA graphics card electrically.
I have reported the issue to the Hewlett Packard Enterprise Community community@hpe.com. Curiously, all confirmation mails from the Hewlett Packard Enterprise Community community@hpe.com concerning the issue in the inbox folder of my email account are currently lost.
Mit freundlichen Grüßen
