Community
cancel
Showing results for
Search instead for
Did you mean:
GDoor
Atom E3845 "No Reboot" Strap?
I'm trying to use the iTCO watchdog in linux running on an Atom E3845, but it is currently failing out due to not being able to unset the NO_REBOOT flag in the PM_CFG register (SIO HSUART core). The E3800 family datasheet says this bit is set on powerup if the "No Reboot" strap is sampled high, but I can't find any other references to the No Reboot strap anywhere in the datasheet. Does anyone know what or where this strap is, and where I can find more documentation on it?
gdoorenb
Community Manager
gdoorenb: Thank you very much for contacting the Intel® Processors communities. We will do our best to try to provide the information you are looking for.
In order to get the most accurate response, please submit your inquiry in our Intel® Embedded communities, you will receive peer to peer assistance in there:
https://embedded.communities.intel.com/community/en/ https://embedded.communities.intel.com/community/en/
Any further questions, please let me know.
Alberto R
