Hi Intel Support,
I want to learn about Intel Xeon D-1559 Boot process. From reset the processor what was happening inside the chip. Please provide technical document to learn.How to start learn and how to understand the basics of the processors.
Thanks in advance,
A. Ajith Kumar
Hello AjithKumar,
Thank you for contacting us. At the moment, we are actively working towards finding an appropriate resolution for your issue, and we will provide you with an update as soon as we can. We kindly request your cooperation during this time.
Vijay N
Intel Customer Support.
Hello AjithKumarA,
Greetings for the day!
This is regarding the case you have with us with the following details.
Case Number: 05999173
Product: Intel Xeon D-1559 Boot process
Issue: What occurs inside the chip of the processor during the reset.
Typically, when a CPU chip receives power, it needs to undergo a reset, which involves sending a reset signal to its RESET (or RST) pin. This is necessary because when the power supply starts up, the CPU may receive unstable voltage levels. Digital logic chips like CPUs require precise voltage levels, and any deviations can cause issues. So, immediately after powering up, the CPU is reset to establish a known starting state. This reset operation is usually handled automatically by the motherboard's circuitry when power is applied. The RESET pin, which is often active-low, needs to be activated for a specific number of clock cycles to reset the CPU. After this reset, the CPU begins its operations.
In essence, the CPU's primary function is to execute instructions from memory. The CPU obtains these instructions from memory, which comprises both RAM (temporary workspace) and ROM (permanent code). RAM is where the CPU temporarily stores data it's actively working with, while ROM contains code that the CPU reads every time it powers up, essentially serving as the initial set of instructions. The CPU communicates with memory (both RAM and ROM) through the address bus, sending specific combinations of 1s and 0s on the address bus lines to select a particular memory location. The memory chips respond by sending the contents of the chosen memory cell over the data bus to the CPU.
Each CPU has a specific memory location where it begins reading instructions after a reset. Some CPUs directly jump to a predetermined point to start execution, while others use a "reset vector" that points to the memory address where instruction execution should commence.
For more detailed information about the processor, please refer to the attached reference link.
https://www.intel.com/content/www/us/en/processors/processor-numbers.html
Please feel free to reach out to us if you require any further assistance or have additional questions. We appreciate your continued use of Intel products and services.
Vijay N
Hello AjithKumarA,
I am sending a follow up if you have any questions from the previous post. If so, please let us know.
Vijay N
Hello AjithKumarA,
We have not received a reply from you, and as such, we will be closing your case.
If you want to continue support, please reply to this email and we will reopen your case or create a new one so that we can continue to support you.
Vijay N
