Processors
16418 Discussions
BSOD I9 13900K with Intel Turbo Boost enabled
Leiruz
GPU rtx 4090 suprim liquid X
Corsair RMX1000W
DDR5600MGH Dominator Ram
2TB Samsung 980 with heatsink SSD
I made a new build yesterday, with semi new pc parts. Everything is new except the motherboard and CPU. Z790 aurous master and I9 13900k cpu. When I was installing windows it wouldn't install without disabling turbo boost. With it disabled the pc boots up and I can run it fine with no problem, the temps are always around 50-55cc while gaming. Only have tested Minecraft and Valorant so far. . I have a custom loop water cooling to help it cool down.
Whenever I enable Intel turbo boost, the pc sometimes wont go past bios, and I also get a bsod. The times it does go pass the bios screen it becomes slow/sluggish. I can watch a youtube video but if I open more tabs it says the tabs are no longer available. When I try to run any game the game crashes, and Ive seen that the temps jump instantly from 48c idle to 90-100c  with the boost on.
Pc works fine without the boost, but I want to be able to use the cpu to its full potential, I also have a custom loop, so im not sure why its getting so hot and crashing whenever I have the boost enabled.
The bios is up to date, I have tried with and without XMP. Ive also cleared CMOS. Is it possible that the Motherboard or CPU could be fault after I switched them out to the new pc build?
Steven_Intel
Hello Leiruz,
I am sorry you are having issues when enabling Intel® Turbo Boost, I will be glad to assist you.
When dealing with this situation, the recommended action is to re-install the operating system. If the issue persists, our best recommendation is to contact the board OEM for further support.
Steven G.
Steven_Intel
We would like to know if you were you able to check the previous post.
Steven G.
Steven_Intel
Since we have not heard back from you, we will close this thread. If you need any additional information, please submit a new question, as this thread will no longer be monitored.
Steven G.
