Processors
16435 Discussions
Because of the CPU, the computer crashes every 30 minutes
luka19
Hello, my cpu i5 2430M turns off every 30 minutes after switching on, but this is not the fault of the temperature or the bios. I have another processor of your production, and it does not turn off like that. I have Graphics
Intel® HD Graphics 3000
AlHill
Sp, one processor works and the other does not?
That would tell me that one processor is faulty  or not supported by your bios.
However, turning off every 30 minutes tells me you have munged the Intel ME in the bios.
Be more specific:  what is the other processor? what is the motherboard and bios level.  Look in the bios and tell use what the ME version is.
[If you find any Intel driver you might need, download and save it now.]
mark38
Have you solved in some way? I've the same problems on a f55a laptop from Asus, original CPU pentium b980 works fine, I upgraded to an i7 2630qm and exactly after 30 minutes pc turns off, tried also disabling every possible hibernate/sleep function
AlHill
@mark38
As I said before - "However, turning off every 30 minutes tells me you have munged the Intel ME in the bios."
