Processors
16331 Discussions
Branchement d'un 3ème moniteur
Jean-Luc8
Bonjour,
Je n’arrive pas à brancher un 3ème moniteur à mon PC Je n’ai qu’un port HDMI. J’ai donc utilisé le port USB-C, mais 3ème écran pas détecté ?.
AlHill
You are in the wrong forum.
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[W10 is this generation's XP]
