Processors
14516 Discussions
BrandString and SPBC fail
FMm
Hello
I run yours Diagnostic Tool and Test called brand string fail result also SPBC test failed
I want to know what is that mean. In pdf file found there on page 20 answer is about older version of program.
This seccond test SPBC fail and in answers is written that my processor is sample. Whats up?
My computer is HP Pavilion dv5 with CPU core 2 duo T5800 2 GHz on mainboard Quanta 3603, chipset PM45.
System: Windows 10 64bit
Please tell me what is wrong.
best on email:
Filip M
Message was edited by: Al Hill
AlHill
Windows 10 is not supported on your processor and chipset.
Windows 10 is not supported on your system by HP as well.
Doc
FMm
On preinstaled windows Vista, Windows 7, Windows 8.1 and now Windows 10 I had the same problem.
Now i use Windows 10 and there is no problem with compability. Only this two tests fail
AlHill
Sorry, but you cannot get support for windows 10.
Have you updated the BIOS on your system?
Have you upgraded the processor on your system?
If only those two tests fail, leave well enough alone.
Doc
FMm
ok I understood. I have another one question: What fastest Intel Processor will be working with my motherboard socket and chipset. I know that changing processor isnt very easy in this laptop, but possible. Maybe another type of core 2 duo or maybe any fastest type.
AlHill
You will have to ask HP what processors are supported by their bios. Then, you can select from those processors. Only HP can provide you this information.
An upgrade processor must be socket, chipset, and bios compatible. And, this is only possible if your existing processor is not soldered to the motherboard.
If you upgraded the processor previously, and did not update the bios or the processor was not supported by the bios, that could be one reason you have a brand string fail.
Doc
FMm
Now I use orginal processor and latest bios, I just wanted to know about Intel socket and chipset. Bios can be manually upgraded or taken from another comp. Im interest only compability with Intels chipset and socket
AlHill
You may find this tool useful: https://ark.intel.com/Search/FeatureFilter?productType=processors Intel® Product Specification Advanced Search
My opinion? Spend your time and money on a new or newer laptop.
Doc
FMm
In most comps right. Too many work, new cooling system and increase of speed very poor. But last year I change CPU in old Asus i3 to i5 and laptop get great boost, later change HD to SSD and its absolutly new laptop.
You see I live in Poland and good, fast laptop is great money problem for me so I combine with things witch I can buy. Sad but true.
And BTW Intel`s new SSD is really so fast and low prize. I was reading many good things about it??
n_scott_pearson
Here's my take on these issues/questions...
  • The Brand String test fails because the Core 2 processors did not support the exposure of a brand string.
  • The SPBC test identifies whether or not the processor is a sample processor. This test may fail because the IPDT program was not designed to support pre-Core processors.
  • As Al indicated, only the manufacturer knows what processors its BIOS will support. Since the choices will be restricted to the processors that will work with the PM45 chipset, we know that this will be limited to other Core2 processor family members. Whether the higher clock rates of other Core2 family processors can be supported and whether the higher thermal dissipation requirements of higher clock rate Core2 Duo processors and all Core2 Quad processors can be met by the cooling capabilities included in this laptop are also questions that only the manufacturer is going to be able to answer.
  • (Opinion) Knowing that the performance improvements possible will be limited to the capabilities offered by higher clock rate Core2 Duo processors and any Core2 Quad processors and knowing how limited these improvements are going to be, I can only agree with Al that this endeavor does not seem worthwhile. You could (fairly cheaply) upgrade to a laptop with a latest generation Atom processor and still see a significant performance improvement over this older laptop with any of the possible processor upgrades.
Just saying,
AlHill
I am also concerned about his statement: "Bios can be manually upgraded or taken from another comp."
Doc
FMm
Bios to ASUS we take from higher model (with the same chipset) and edit diffrences from old bios. Only number of processor (Very Very long number) we find in forum for electronics and part of bios code with informations about Type, Frequency, Model, Family etc. We was sure that cant work.
But I was suprised when laptop starts. 3 sec later Problem will be with memory and method of trying and loose will solve this problem (about 2 hours of trying). Now laptop works on this new CPU with bigger fan and make better air flow. Better radiator and more holes in case.
In benchmark there was 9-11% better. In normal working- no change.
Lot of work but effects...poor.
I ask you about changing Cpu in HP but I cant find anything...
Thanks a lot,
Filip
AlHill
There are so many things wrong about this thread, I am going to stop following it.
Doc
FMm
hi.
you are absolutly right in your answer, but prize of new Atom`s Laptops is still high. So i must help myself.
Thanks for answer,
Filip
FMm
it was very low chanse to do that, but its working. You can find DIY electronics. So not only me get success.
Filip
FMm
Mayby have you any promotion on SSD, laptops or another hardware. Older models or used things will be ok.
Filip
Hello ozinaha,
Thank you for your response.
Intel ® does not sell directly. If you are looking for promotions, we encourage you to contact one of our distributors or vendors so they can tell you if they are having any kind of promotion or discount with the different devices. You can check the approved distributors below:
https://www.intel.com/content/www/us/en/partner/where-to-buy/overview.html https://www.intel.com/content/www/us/en/partner/where-to-buy/overview.html
Also, you can check the different stores near your area or country in the link below:
https://www.intel.com/content/www/us/en/products/find-a-reseller.html https://www.intel.com/content/www/us/en/products/find-a-reseller.html
I hope this helps.
David V
Hello ozinaha,
I am following up with your case and see that we have not heard back from you.
If you need more assistance do not hesitate to reply.
David V
FMm
sorry for my late response, but I have my first summer vacation for 3 years and of course there was a problem with Internet (in Poland that is normal when you leave a big city and in smaller city)
Now I back to Warsaw and I hope its finish with my Internet connection problems.
Lets back to bottom line - thanks a lot for list of reseller Intel products. I contact with those firms and ask about having any kind of promotion or discount with the different devices (frequently with Intel parts and all devices).
Unfortunately, no effect ( suggestions about 3- 5 % with computer which costs near 2000 $).
On separate parts (CPU, SSD) there is no promotion.
Some firms I visit personally to ask about work (I'm IT specialist and bioengineering).
Maybe Intel needs employee in Poland??
So thanks a lot.
Filip M
Hello ozinaha,
In this case, that is the way we have in order to provide you with any kind of promotion, this is because Intel ® does not sell directly. If there is anything like that available it is handled and managed by the different vendors/distributors.
I apologize for any inconvenience.
David V
