hi,
i try to run Windows 7/10 on a Zotac zBox ci323 with Celeron N3150. when install 2x2 GB RAM it still report 2 GB RAM while GFK limit it ?
i ask Zotac and they say it is a Intel Grafic Driver Problem.
at begin i installed Zotac GFK Driver and than
try Intel Driver Assistent. 3 Updates are found but only Wifi and BT are installed ... GFK fail ?!
i did manual extract file and installed lates 15.5058
but Problem is still the same only 2 GB RAM is shown instead of 3 GB for Work with 32 Bit Windows 7 / 10 like on older CPU ?
- « Previous
- 1
- 2
- Next »
hi,
> Here https://www.intel.com/content/www/us/en/support/articles/000006105/processors.html you can find the processors that have Windows® 10 32-bit
i have read that Page but it show only Windows 10 Driver. It make People think that Haswell & Broadwell CPU does not work with Windows 10 but Windows 7/8 Driver also work, or ?
have a look at i7-6700 where i found Windows 7 32-Bit Driver
it is difficult to check CPU this Way if they have Windows 7/8 32-Bit Driver.
is there a other Way to find out which Intel CPU have Windows 7/8 32-Bit Driver ?
mfg Yiu
- « Previous
- 1
- 2
- Next »
