Processors
16309 Discussions
CAD rendering dual xeon vs 990x
I am looking to put together a CAD machine and have had good luck with the 980x procs but was wondering if a dual xeon config would be better. If anyone has any feedback or good threads discussing this it would be much apreciated. Also, I am looking at roughly $1000 per machine for procs so that puts me in the 5 series or E3 series xeons. The main concern is render time as well, trying to cut down the 24 hour renders. Thanks for any feedback.
DSilv11
Valued Contributor III
Here is a thread I worked some issue in with a 3d animation and visual effects designer.
He built a killer system!
/message/119067# 119067 http://communities.intel.com/message/119067# 119067
Hello
I read your notes, and I am nearly bought a system with 990x, have you had any feedback, I got or had in the past a xeon server that I converted to pc so I could do farming but never had success+xeon fans very noisy, it could be I was using a converted server nevertheless it was not a match to I7-920mhz.
I understand that xeons need to be double which means a different matherboard,, I never found about multy tasking of xeons i,e different applications at sametime which doesnt work on 920 at all, one CADxAccurender image per time. Well hope you got some feedback I am very keen to buy the fastest intel avilable for 3 years to come.
Regards Libaax5
