Hi, This morning I noticed slowdowns when running various software. I did a test with the diagnostic tool and this is the result:
What can i do? the motherboard has the default values.
--- IPDT64 - Revision: 3.0.0.23.W.MP
--- IPDT64 - Start Time: 29/02/2016 18:36:21
Processor 1
Intel(R) spbc Module Test
Module Version: 1.0.7.64b.W
Start Time: Mon Feb 29 18:36:22 2016
Test Result - PASS
..!!..Processor under test is verified as 'PRODUCTION'..!!..
Processor Manufacturer: GenuineIntel
Processor Brand String: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
End Time: Mon Feb 29 18:36:22 2016
Total Time: seconds: 0
Genuine Intel CPU Test
Module Version: 1.0.12.64b.W
Test Result - PASS
Expected: GenuineIntel
Detected: GenuineIntel
Temperature Test
Start Time: Mon Feb 29 18:36:23 2016
Test Result - PASS
Expected: Greater than 1 degrees below max
Received: 73 degrees below max
End Time: Mon Feb 29 18:36:23 2016
CPU Brand String Test
Test Result - PASS
Expected String Parts: As Defined in BrandString_LocalConfig.xml
Detected: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
Module - CPUFreq.exe did not create a results file.
--- IPDT64 - Temperature Monitor Results
Temperature Monitor will begin when CPULoad Test starts
Temperature Monitor Stopped
System Information
Processor Name: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
Processor Information: Intel64 Family 6 Model 60 Stepping 3
Number of Physical Cores: 4
Number of Logical Cores: 8
Installed System Memory: 8 GB
Operating System: Microsoft Windows 10 Pro 64 bit
Graphics Information: Intel(R) HD Graphics 4600
System Product: Z87 MPOWER MAX (MS-7815)
System BIOS: V1.10
System Serial Number: To be filled by O.E.M.
--- IPDT64 - End Time: 29/02/2016 18:36:25
--- IPDT64 - Result: Fail
FAIL
Hello, Liros:
Please try to load the default settings one more time and try with the following Intel® Processor Diagnostic Tool version https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool Download Intel® Processor Diagnostic Tool.
