Processors
16441 Discussions
CPU Geschwindigkeit I7-8700K
DL3ED
Hallo,
ich habe das Problem das meine CPU I7-8700K nur noch mit 800MHz läuft.
Wie kann man die Erhöhen.
Wo kann man nachsehen warum das so ist.
Gruß Ulrich
FrancisP_Intel
Hello DL3ED,
Thank you for posting in Intel Communities. We understand that your processor is operating below the base frequency and we'll assist you in looking into this matter. In the meantime, we would like to better understand the situation. Therefore, we kindly request your cooperation in providing us with information.
  • Which monitoring software are you using to check on the processor's frequency?
  • Was this previously running at 800Mhz or are there instances only?
  • Aside from the reported frequency, are there other symptoms the system is experiencing? Like crashing applications or systems (BSOD)?
  • Have you made any changes like software, driver, recent installations, or hardware upgrades that resulted in this issue? This will allow us to check if any of the recent changes or updates are incompatible or causing an issue with the processor's performance
  • Have you performed any troubleshooting steps in an attempt to fix the problem?
  • Is this a newly installed system? It can help us understand if the issue stemmed from incompatibility or misconfigured installation.
We may have follow-up questions depending on your answer. We look forward to your response.
Francis Ryan P.
FrancisP_Intel
Hello DL3ED,
I wanted to check in and see if you've had a chance to review our previous message. Please let me know if you have any further questions or need clarification on this issue.
Francis Ryan P.
JeanetteC_Intel
Hello DL3ED,
As we have not heard from you for the past few days, we will proceed in closing this thread. Should you need assistance in the future, please submit a new question as this thread will no longer be monitored.
Sincerely,
Jeanette C.
