I had a DELL laptop with Intel Core I5 7200U @2.5 GHz. But when starting up the computer, the CPU speed goes to 3.0 GHz+ which not make any sound. And when run a game which it goes up to 3.1 GHz+. But the CPU's utilization goes high up to 60%. Is it ok? And his happen after install another 4 GB ram to the old laptop to get 8 GB. And the laptop had been used 2 years.
So, what is the problem?
What version of Windows 10 are you using?
Go to start, settings, system, about to get the version information at the bottom of the page.
Doc
No, that is not the version.
Go to start, settings, system, about to get the version information at the bottom of the page. It will be some number like 1803, 1809, 1903, etv.
Doc
Last version of windows. I don't know what version is it but I use Windows 10 Upgrade Assistant to update windows to the last version.
Or, you could simply go to:
START
SETTINGS
SYSTEM
ABOUT
and get the correct answer. It is not that difficult.
Doc
Hi @TKhov ,
- Download and install Intel System Support Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
- Run the test and you will see if the CPU works as should be.
Leon
Yes, this is all perfectly fine. This is simply the Turbo Boost feature taking some/all of the cores to higher clock speeds based on current workload, temperature, etc.
