Hi is setting the max cpu state to 99% going to damage it or have any negative actions on my hardwar MSI GF75 Thin I7 10750 H RTX 3060
Because the temp is realy high 95C whyle gaming and sometimes just by using chrome or any other task it go up to 90C Even if using fan boos mode in dragon center
PLZ HELP
- Tags:
- CPU temperatur
Hello Bun,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® Core™ i7-10750H Processor.
1. Where are you seeing the temperatures? Can you take a picture?
2. Are you using a laptop or desktop computer?
3. Are the fans spinning?
4. Is this issue recent? If so, when did it start?
5. Is the unit stack at 95 degrees for long periods of time or are they only spikes?
Deivid A.
Laptop MSI GF 75 Thin using dragon center
Whyle gaming the temps are above 90c allthe time ++++ Max Fans Active
i don't know if this issue is recent or not sorry i cna't remember anything becaure when i got this pc i was using silent mode and i never cheked the temps this summer when i started gaming on it i started using balenced mode or bosst mode and i paid atention to the temps ....
'//Whyle gaming the temps are above 90c allthe time ++++ Max Fans Active
'//doing simple tasks it changes from 50 to 90 like watching youtube openng a new tabs in chrom then it gets stable at 60 C but as soon as i click on somthing you hear the fans spining for 6s then back to 60C and undervolt is blocked + i dont want to do it cause i think ill damage my pc
'//and i dont think the chip is damaged at all because in task manager i get up to 4.5 Ghz
The thing is what i want is a safe method to make the processor not getting hot by just youtube or chrm tabs because i know that this cpu can do a lot of things just by the base clock there is no need to go up to 4Ghz then to 1.2Ghz becuse i tried detting the max state at 99% and the cpu was cool
PLZ HELP Sir Deivid A . Bun
Hello Bun,
Thanks for the information provided. Based on your system I recommend you to try the following:
1. Try to load your BIOS to default settings.
2. Make sure with MSI that you have the latest BIOS installed
3. Make sure that there is no obstruction in the laptop vents.
However, the best recommendation is to check with MSI to confirm that the thermal paste is properly applied and the colling solution is working properly. Bear in mind that this is a highly customized system and MSI may need to inspect your laptop's hardware to make sure that everything is working properly.
Deivid A.
Thanks For your answer ill try those steps
but still my question will setting the max cpu state to 99% damage it
Hello Bun,
Thanks for the confirmation. I will be waiting for the results of these steps.
Based on your CPU specifications, your CPU can support up to 100°C, and any temperature above that or if the temperature is stocked above this will damage the processor and the laptop too.
Deivid A.
Hello Bun,
After checking your thread, I would like to know if you need further assistance.
If so, please let me know.
Deivid A.
Hello Bun,
I was checking your thread and see that we have not heard back from you.
I’m going to close your post, but if you need further assistance, please do not hesitate to create a new thread.
Deivid A.
You didn't tell me will setting the max cpu state to 99% damage it not ////the temmp
you know the setting in control panel
