Processors
14534 Discussions
CPU and memory issues
I have a technical problem. I have to upgrade my RAM on my desktop.
Specifications :
CPU - Intel core i5 750 @ 2.67 GHz, Lynnfeild, socket 1156 LGA
Mother board: ASUS P7P55D
Operating system: Windows home premium, 64 bit.
Now I checked on the Intel site - this CPU supports DDR 3 RAM upto 1333 Mhz only. Any faster , I will have to overclock the CPU. FSB to 160 from 150. Maybe tinker with the BIOS. I do not want to do that.
The motherboard however is compatible with 1600 MHz speeds.
Both Corsair and Crucial sites say DDR 3 1600 MHz will work, but neither consider the CPU, they only ask about the motherboard type and number.
Which RAM will be compatible with my system? I plan 2 X 4 GB = 8 GB, should be OK with my OS. I want to use 1600 Mhz , but this may not work.
TO add to the confusion an Intel document says 1600 Mz is compatible - http://www.intel.com/en_US/Assets/PDF/prodspec/ww02-2011-XMP-self-cert_Core-i5-BlueBadge.pdf http://www.intel.com/en_US/Assets/PDF/prodspec/ww02-2011-XMP-self-cert_Core-i5-BlueBadge.pdf
Obliged if someone can shed light.
Adolfo_S_Intel2
You can install RAM running at 1600 MHz but this RAM will be running only at 1333 MHz, since this is the maximum supported by the processor.
Basically, since the RAM will be running at slower speed, then there is no point on installing faster RAM that the one that the processor supports, in other words we recommend installing the RAM that will run at the speed the processor supports.
