Processors
16442 Discussions
CPU i7 14700 + ddr5 2x16gb 5600mhz will maintain 5600mhz with 4x16gb?
LPP_BRpc
I have an intel core i7 14700, along with 2x16gb corsair vengeance ddr5 5600mhz ram on an Asus ProArt B760 Creator motherboard (ATX/DDR5), I intend to buy +2 ram from the same 2x16gb kit, but I would like to know if the controller can contain 4x16gb at 5600mhz (I'm not going to overclock) or could it damage it, otherwise the frequency would drop below 5600mhz?
Tenho um intel core i7 14700, junto com 2x16gb corsair vengeance ddr5 5600mhz ram em uma placa-mãe Asus ProArt B760 Creator (ATX/DDR5), pretendo comprar +2 ram do mesmo kit 2x16gb, mas gostaria de saber se o o controlador pode conter 4x16gb a 5600mhz (não vou fazer overclock) ou pode danificá-lo, caso contrário a frequência cairia abaixo de 5600mhz?
RamyerM_Intel
Hello LPP_BRpc,
Thank you for reaching out to the community. After reviewing the specifications, I can confirm that the Intel i7 14700 processor supports memory types of up to DDR5 5600 MT/s. For detailed CPU specifications, you may refer to this official link. Additionally, considering your choice of the Asus ProArt B760 Creator motherboard (ATX/DDR5), I have verified its specifications and can confirm that it is compatible with the 4x16GB at 5600MHz RAM configuration you intend to use, as detailed on page 22 of the motherboard's manual.
However, since this is an original equipment manufacturer (OEM) motherboard, please take into consideration that our support may be limited since we are not familiar with the technology, settings, customizations, custom drivers, and features that the OEM has designed and installed your system. As such, I highly recommend confirming this with ASUS as well so you will be able to setup the 4x16gb at 5600mhz of RAM that you want to use alongside the i7 14700.
Ramyer M.
