Hello.
Im here because amazon told me .
I bought a 6700k and im experiencing some weird issues.
Randomly the pc stutters, something that never happened before.
To see whats happenin i used a software to register all the hardware during this stutter.
So everytime the pc stutters the cpu goes crazy and gives a peak on its load.
So i conclude the cpu is the cause of the stuttering problem.
But... i dont know what to do .
Hi Alintel,
Let's try to test your system with the Intel® Processor Diagnostic Tool, to verify the functionality of your system. The diagnostic checks for brand identification, verifies the processor operating frequency, tests specific processor features, and performs a stress test on the processor.
Please attach the results to your answer.
https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool
Hellen.
Thank you.
There it is:
--- IPDT64 - Revision: 3.0.0.25.W.MP
--- IPDT64 - Start Time: 20/07/2016 17:24:18
Processor 1
Intel(R) spbc Module Test
Module Version: 1.0.7.64b.W
Start Time: Wed Jul 20 17:24:18 2016
Test Result - PASS
..!!..Processor under test is verified as 'PRODUCTION'..!!..
Processor Manufacturer: GenuineIntel
Processor Brand String: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
End Time: Wed Jul 20 17:24:18 2016
Total Time: seconds: 0
Genuine Intel CPU Test
Module Version: 1.0.12.64b.W
Start Time: Wed Jul 20 17:24:19 2016
Test Result - PASS
Expected: GenuineIntel
Detected: GenuineIntel
End Time: Wed Jul 20 17:24:19 2016
Temperature Test
Test Result - PASS
Expected: Greater than 1 degrees below max
Received: 67 degrees below max
CPU Brand String Test
Test Result - PASS
Expected String Parts: As Defined in BrandString_LocalConfig.xml
Detected: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
CPU Frequency Test
Module Version: 1.0.14.64b.W
Test Result - PASS
Processor Name: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
Expected CPU Frequency: 4.00
Detected CPU Frequency: 3.91887
Expected Base Clock: 100
Detected Base Clock: 100.484
QPI link rate Test - Not supported.
Skipping QPI link rate Test.
End Time: Wed Jul 20 17:24:21 2016
Total Time: seconds: 2
Floating Point Test
Module Version: 1.0.10.64b.W
Start Time: Wed Jul 20 17:24:21 2016
Test Result - PASS
Million Floating Points per Second, MFLOPS: 648
Error: 0
--- Floating Point Test Passed!!!---
End Time: Wed Jul 20 17:24:23 2016
Prime Number Generation Test
Start Time: Wed Jul 20 17:24:23 2016
Test Result - PASS
Operation Per Second: 4.65205e+006
Error: 0
--- Prime Number Generation Test Passed!!!---
End Time: Wed Jul 20 17:24:25 2016
Cache Test
Start Time: Wed Jul 20 17:24:25 2016
Test Result - PASS
--- Reading Cache Size ---
- Detected L1 Data Cache Size --> 32
- Detected L1 Inst Cache Size --> 32
- Detected L2 Cache Size --> 256
- Detected L3 Cache Size --> 8192
Cache Size Test Passed!!!
MMXSSE Test
Test Result - PASS
--- Determining MMX - SSE capabilities ---
--- CPU FEATURES DETECTION FOR ---
--- MMX SSE ---
MMX - MMX Supported --> Yes
SSE - SSE Supported --> Yes
SSE2 - SSE2 Supported --> Yes
SSE3 - SSE3 Supported --> Yes
SSSE3 - SSSE3 Supported --> Yes
SSE4.1 - SSE4.1 Supported --> Yes
SSE4.2 - SSE4.2 Supported --> Yes
--- MMX SSE - capabilities check complete ---
MMX Test Result --- PASS
SSE Test Result --- PASS
SSE2 Test Result --- PASS
SSE3 Test Result --- PASS
SSSE3 Test Result --- PASS
SSE4.1 Test Result --- PASS
SSE4.2 Test Result --- PASS
AVX Test
Module Version: 1.0.11.64b.W
Test Result - PASS
--- Determining AVX AES PCLMULQDQ capabilities ---
--- AVX/AES/PCLMULQDQ ---
AVX - Advanced Vector Extensions Supported --> Yes
AVX OS Support - AVX Operating System Supported --> Yes
AES - Advanced Encryption Standard Supported --> Yes
PCLMULQDQ - Polys Carry-Less Multiply Supported --> Yes
--- AVX AES PCLMULQDQ capabilities check complete ---
AVX Compare Test Result --- PASS
AES Test Result --- PASS
PCLMULQDQ Test Result --- PASS
IMC Test
Test Result - PASS
--- Reading Memory Size ---
Detected Memory Size is --> 8.00GB
--- Subtest - Memory Size Test Passed!!! ---
--- Integrated Memory Controller Stress Test ---
Memory to be allocated = 1048576 byte
Memory Allocated.
Test 1 Ones and Zeros Moving Inversions write operations - Passed
Test 1 Ones and Zeros Moving Inversions verification operations - Passed
Test 2 32Bits Sliding Ones write operations - Passed
Test 2 32Bits Sliding Ones verification operations - Passed
Test 3 32Bits Sliding Zero write operations - Passed
Test 3 32Bits Sliding Zero verification operations - Passed
Memory Deallocated.
--- Subtest - Memory Stress Test Passed!!! ---
Integrated Memory Controller Stress Test Passed!!!
End Time: Wed Jul 20 17:24:26 2016
Total Time: seconds: 1
PCH Test
Module Version: 1.0.9.64b.W
Start Time: Wed Jul 20 17:24:26 2016
Test Result - PASS
Chipset : Skylake Platform Controller Hub
No device connected to PCI Express Port 1
1 device connected to PCI Express Port 9</...
Hi Alintel,
I noticed that your processor is working as it should; it passed all the tests, Could you please attach the result of the Intel® System Support Utility, to get more information about your system configuration.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Hellen.
Hi Alintel,
I would like to know if your system is working properly.
Hellen.
Well i dont know what to say or what to do.
Ill try the system support utility and post the results.
Thank you.
Hi Alintel,
I would like to help you on this, I request the SSU to get more information about your system in general.
Hellen.
Hi Alintel,
Thought I would just check in and find out if you need further assistance on this matter.
Hellen.
