Hallo ich wollte meinen Core 2 Duo E6300 gegen einen Core 2 Quad Q8200 wechseln. Als ich den eingebaut habe ging der pc an aber da war die ganze zeit nur schwarz ala ich dan den anderen eingebaut hab lief alles wieder
Here is a comparison of your two processors: http://ark.intel.com/compare/36547,27248 Intel® Product Specification Comparison
While they are socket compatible, an upgrade processor must also be supported by the BIOS of your motherboard.
You MUST ask the motherboard/system manufacturer what processors are supported by THEIR BIOS. Then, you can select from those processors.
If the upgrade processor is supported by the BIOS, it is possible that you need to update the bios prior to installing the upgrade processor.
https://www.intel.com/content/www/us/en/support/processors/000005682.html Intel® Desktop Processor Upgrade Information
Doc
Doc
