Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Can I use a 7th gen processor on a 6th gen motherboard?
I've been trying to build a custom PC on my own so i went for a search.
I found the MSI B150 Gaming M3 motherboard, i went through the specifications.
It supports the 6th gen CPU, it isn't declared that it only supports it but only that it supports.
The only processor i found available was the 7th gen.
So am asking if i can buy the 7th gen and use it on the motherboard?
Will it work?
Wouldn't there be any problems?
Highlighted
You can only use the processors that the MSI BIOS supports:
https://us.msi.com/Motherboard/support/B150-GAMING-M3.html# support-cpu Support For B150 GAMING M3 | Motherboard - The world leader in motherboard design | MSI USA
Doc
