Hello PSHAN12,
Thank you for contacting Intel Customer Support.
We do understand that you would like to know if you can use an Intel® Xeon® Gold 6148 Processor and Intel® Xeon® Gold 6138 Processor on a dual CPU board.
Please bear in mind that Intel supports and validates two and four-processor configurations only where all the processors operate with the same Intel® UPI ( UltraPath Interconnect) frequency, core frequency, power segment, and have the same internal caches sizes. Mixing components operating at different internal clock frequencies is not supported and will not be validated by Intel. Combining processors from different power segments is also not supported and might not function properly.
You can find more information here Second Generation Intel® Xeon® Scalable Processors Datasheet, Vol. 1
Section 2.5, page 33.
Please let us know if you need further assistance.
Sergio S.
For firmware updates and troubleshooting tips, visit :https://intel.com/support/serverbios
Hello PSHAN12,
We are following your question in regards to your Intel® Xeon® Gold 6148 and Intel® Xeon® Gold 6138 Processors and we would like to know if you need further assistance.
Sergio S.
Hello PSHAN12,
Sergio S.
Hello PSHAN12,
We are following up on a case that is still open with your question if an Intel Xeon Gold 6148 2.0Ghz and the 6138 can work together on a dual CPU board we know that this is important for you to get it resolved and it is also equally important for us to get you the right solution.
Since we have not seen an update for several days, the case will automatically close after 2 business days. You can still re-open the case by logging into your web portal or replying to this thread. Please note that if the case is re-opened more than 15 days after closure, a new case will be created with a reference to the original case.
Sergio S.
