I've been getting a heep of blue screens have stress tested (cpu, ram, gpu) all seem fine, temps are good. I've clean installed windows on a new drive, updated drivers but cant get rid of it.
Error as follows with link to mini dumps below. Thanks
Problem signature
Problem Event Name: BlueScreen
Code: 124
Parameter 1: 0
Parameter 2: ffffe48d43674028
Parameter 3: bb800000
Parameter 4: 174
OS version: 10_0_22621
Service Pack: 0_0
Product: 768_1
OS Version: 10.0.22621.2.0.0.768.101
Locale ID: 2057
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
