Processors
14512 Discussions
Can i sum speed of two core, need document had that informatin
AGonz46
n_scott_pearson
Huh? Please explain your question better.
AGonz46
if i had 1 processors with 2 cores and speed is 1.0 ghz, those core be sum and the result are : 2.0 ghz?. i need official document explain that
n_scott_pearson
No, the result isn't 2.0 GHz; it is still 1.0 GHz.
You can start with this page to find documentation on the processors, by type and generation: https://www.intel.com/content/www/us/en/products/docs/processors/core/core-technical-resources.html.
I suggest that you also learn about symmetric multiprocessing: https://en.wikipedia.org/wiki/Symmetric_multiprocessing.
AGonz46
Thanks for you services, do you have a INTEL's document talk about it criteria( cores work separate or the speed could be sum ) ?
n_scott_pearson
Did you read the article on SMP? That is where you need to start to understand how this works.
