Community
cancel
Showing results for
Search instead for
Did you mean:
SLitw
Can i use 8700K with 2133mhz memory DDR4?
Hi.
Hi. My rams:
https://www.kingston.com/datasheets/HX421C14FB2K2_16.pdf
https://www.morele.net/pamiec-hyperx-fury-ddr4-2x8gb-2133mhz-cl14-hx421c14fb2k2-16-869008/
Currently are on Asus Z170-P motherb and 6700K. I am buying 8700K and Asus Tuf Z370 Pro Gaming.
https://www.morele.net/plyta-glowna-asus-tuf-z370-pro-gaming-1612190/
I must buy faster new ram or not necessary ? I dont have much money and i must safe cash for mobo.
And why on intel specification is 2666mhz memory,look:
https://ark.intel.com/products/126684/Intel-Core-i7-8700K-Processor-12M-Cache-up-to-4_70-GHz
So this mean i will be have bootleneck?
So right now me having lower MHz ram than Intel actually recommends slows down the CPU or not really?
I read many reviews that difference between 2133mhz vs 2666mhz are large and shows 20-30 fps difference.
Other reviews shows 2-3 fps marginal difference.
Like i said i must safe cash for 1080 ti . Can i use them 2133mhz for short time with 8700K ( stock ) ?
n_scott_pearson
Super User Retired Employee
Your 2133 memory should work just fine. The number you see on ARK is the maximum validated speed; slower speeds are also fully supported.
