Community
cancel
Showing results for
Search instead for
Did you mean:
KKeri
Can i use Intel® Xeon® E5-2620v4 and Intel® Xeon® E5-2620v3 together
Hello dears. Please help me.
I have a HP ProLiant ML350 Gen9 Server and currently i use Intel® Xeon® E5-2620v4 possessor. But this server has two socket and i have an Intel® Xeon® E5-2620v3 CPU optional. I do not know can i use these together? Or they do not work?
CWon1
My question is similar to yours. i have know the same cores, same cache ,and the same technology can be worked together.
Community Manager
crysty: Thank you for sharing your problem in this thread.
If you are facing a similar problem I will recommend opening a new thread so we can provide you with further assistance. Please make sure you provide a clear explanation of your issue and attach your system specifications.
Antony S.
Community Manager
Hello, kkerimov.
Thank you very much for contacting the Intel® Communities Team.
I understand you would like to know if it is possible to use another Intel® Xeon® processor on your HP* system. Allow me to help you regarding this question you have.
In this case, I will highly recommend you to get in touch with https://www.support.hp.com/us-en HP * Support to verify if there is any restriction for you to use these two processors together on your mainboard.
Antony S.
