Hi everyone!
I am facing a problem with installing the intel processor identification utility. shows error code: 2417213376. Please help me to solve this issue.
What is the processor model number?
Provide the link from where you are downloading the utility.
My pc processor number is :
Intel(R) Core(TM) i3-3220 CPU @ 3.30 GHz 3.30 GHz
I have downloaded it from this link:
http://support.intel.com/support/processors/tools/piu/sb/cs-014921.htm
Download from here:
I am facing the same problem while installing it from your link.
Then, you likely have a windows problem.
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
Here are the results of the utility. Check out the attached files.
Hi @Husneara
Did you tried to install the Intel Processor Diagnostic Tool? Do you have Windows 10 O.S.?
Leon
No, I did not install Intel Processor Diagnostic Tool. I use Windows 7 OS.
I have attached the test result that I have done with Intel Processor Diagnostic Tool.
Ok, are we talking about the Intel processor identification utility
or the Intel processor diagnostic tool?
I gave you a link to the Intel processor identification utility. Did you try it?
Sorry, I did not find any link. Will you please send it again?
scroll down in this thread.
Hello Husneara, Thank you for posting in the Intel® Communities Support.
I just wanted to check if the issue with the Intel® Processor Identification Utility still persists and if you need further assistance on this matter?
Albert R.
A Contingent Worker at Intel
Hello Husneara, Since I have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
