Trying to get an old PC running for my sister. It's an Intel chipset mobo, model dq77mk. I tried to flash the bios with the newest one, computer froze. Tried flashing with the next update from the beginning, and go gradually up, but while that didnt freeze, at the end it says "flash update failed". Apparently my mobo is so old that it has a "legacy bios" on it. The newest bios is I think 0074, Im way back on 0051. Cant upgrade to the very next version (appears to try and flash, but error message at the end), or the very newest one (instant freeze/lockup when I press 'Y' to confirm). Am I just SOL?
I've checked the 'discontinued support' section already and found nothing applicable to my issue.
Thank you for any help.
Now, being unable to initialize memory can have a lot of possible causes. It is usually bad or incompatible memory, but the failure could also be in the processor's memory controllers or in the memory bus(s) implemented on the motherboard (electrical noise is the common issue).
You have a very old motherboard. Every component present - including even the solder used - is well beyond its MTBF date. There are many components that, should they fail, could render the entire system inoperable.
You need to install the latest BIOS package (which I have attached) using the BIOS Recovery process. Here is my process for doing so:
- NOTE: Read these instructions completely before starting. Follow all instructions EXACTLY.
- On some other Windows-based PC, download the .BIO file for the BIOS release you wish to install.
- Insert a 32GB or smaller (the smaller the better) USB 2.0 flash drive into the PC. Do not use USB 3.0 flash drives (most are not compatible). It is also better (though not required) to use a flash drive that has an access LED that you can watch.
- Format this USB flash drive using the Windows Format applet. Specify to install the FAT32 file system (Important: NOT vFAT, NOT exFAT; FAT32 only). You must also specify that the Quick Format option be Disabled (unchecked).
- NOTE: If FAT32 is not offered as a choice by the Format applet, your flash drive is too big; use another.
- Copy the .BIO file into the root folder of this USB flash drive. This should be the only .BIO file in the root folder of this USB flash drive.
- Properly eject the USB flash drive. Do not just yank it out. Do this from File Explorer or using the Safely Remove Hardware and Eject Media System Tray applet.
- Power off the Desktop Board system.
- Remove the yellow BIOS Configuration jumper from the board. It will be the only yellow jumper; the rest will be black.
- Plug the USB flash drive into one of the black USB 2.0 ports on the back panel of the board. Avoid using blue USB 3.0 or Yellow USB 2.0/3.0 charging ports. Also, avoid using front panel USB ports.
- Power on the system.
- The BIOS Recovery process should start automatically. You should see a progress report on your main monitor.
- NOTE: If you do not see a progress report displayed on a monitor, do not power off the system for at least 15 minutes. While it is rare, it is possible for the process to proceed without an onscreen display; you must give it ample time to complete, just in case.
- When the BIOS Recovery process is complete, you will be asked to power off the system. Do so then.
- Restore the yellow BIOS Configuration jumper to the pins it was on previously. This should be across pins 1 and 2 of this (three pin) header.
- Remove the USB flash drive from the back panel of the board.
- Power on the board.
- Immediately begin pressing the F2 key, over and over (approx. once per second) until you see a BIOS Setup (or Visual BIOS) screen displayed.
- Verify, using the BIOS version string, that the BIOS installed properly. Stop if it isn't.
- Press the F9 key (followed by the Y key) to reset of the BIOS configuration.
- Press the F10 key (followed by the Y key) to save the BIOS Configuration and exit BIOS Setup.
- Once screen is cleared (goes black), begin pressing the F2 key, over and over, until you see the BIOS Setup screen displayed.
- Make any changes to the BIOS configuration that you desire (for example, disabling NUMLOCK) or that you require (for example, setting Boot Order, enabling UEFI, etc.).
- Test.
Here are some additional thoughts:
- If BIOS Recovery will not start, try using a different USB port. You can try using the blue USB 3.0 or yellow USB 2.0/3.0 ports as well if no other choices. You can also try using front panel USB ports.
- If switching USB ports didn't work, try using a different USB flash drive. Remember that all USB flash drives must be reformatted at least once using the process described in Step 4 above.
- As always, it is helpful to use a USB flash drive that has an access LED so that you can visually see if it is being accessed.
- If you are seeing USB flash drive being accessed but BIOS Recovery does not start, a common cause is compatibility with the memory present. The BIOS Recovery engine, as it is with USB 3.0 flash drives, can be very picky with regards to memory compatibility. Try removing all but one DIMM/SODIMM.
- For more information on the BIOS Recovery process, consult Intel Desktop Boards Recovery BIOS Update Instructions.
Hope this helps,
Thank you very much. There's a few steps in here I did not take. I'll try again and report back.
Jordan
Hi there, just reporting back. No luck. Froze in the exact same spot. I followed you instructions exactly. Couple questions tho. When I am supposed to actually push the update? Once Ive taken off the jumper and booted into the bios repair/restore? Or do I do all that, repair it, put jumper back in, and then push the update. Every step was easily understandable and was going well...right up until that exact moment. This is when my screen freezes.
Thanks, Jordan
Not sure what you mean by 'push the update' or 'repair'. When you power on with the jumper removed (the yellow one), the BIOS will automatically start the recovery process using the single .BIO file that is in the root folder of the flash disk. You do nothing (no F7 at any point!) until it tells you to power back off.
When I power on with the jumper removed I dont get a display. I waited 15 minutes like suggested and restarted it. It still was at BIOS version 54.
I just noticed it DID move from 51 to 54. Is BIOS version 54 possibly the latest it can handle? A 0074 bio was in the root directory of the flash drive.
Hmm. Maybe thats it. I recently stuck an i7-3770 in there to replace a i5-3450. Could that affect bios updates?
Not sure what to think. Let me mull this over...
Im completely stumped as well. Mostly stumped on why I get no video when rebooting with the jumper totally removed. At least I got from 0051 to 0054
I appreciate your help so much, and I'll respond back if I figure anything out either. Just for nerd stats, Im using a Sandisk Cruzer 4MB, older USB drive I have. Plugging into the back of the PC, in a black colored plug. Unplugged xbox controller, mouse, and ethernet. Only thing plugged in was keyboard and hdmi monitor.
Thanks again for all the help, I'll keep at it.
Jordan
Couldnt have anything to do with the coin cell batter dying, could it? It's about 13 years old at this point and I did notice the time on my pc randomly change twice over the last month or so.
Ordered some new coin cells the other day thinking it'd be a good idea anyway. Its been maybe 7 years, this computer was partly in storage. Thanks again for all the help and time you've spent, I really appreciate it. I'll let you know if a new battery changes anything.
Any clue, however, why I get no display with the jumper removed completely?
Jordan
There is another two variants how to fix it.
1.
You will need a programmer, a soldering iron and the ability to use it.
There is a lot of information about reflashing bios chip in the internet.
What you need to pay attention to:
• For an inexperienced person, desoldering chips, flashing chips, soldering chips; This is a risky process; if something goes wrong, it will be impossible to do without professional repairs.
• Specifically for this board, BIOS on two chips 8MiB and 4MiB.
• ".BIO file was an EFI capsule around the original bios binary". you need to get original bios binary from this
• You need to split bios binary file to two parts 8MiB and 4MiB. (8MiB the first part)
• Make dump, to have ability to restore all to previous state.
• Bios chips next to the gray sata connector.
• First part flash to 25Q64BVSIG chip (8MiB). Second part flash to 25Q32BVSIG chip (4MiB).
I also have this board and I have already flashed the modified BIOS (to boot from nvme) to it in this way. I can write more detail if necessary.
2.
You can find someone who have programmer, soldering iron and ability to use it.
It shouldn't cost much. This is 30 minutes of work for profesional in worst scenario. Unsolder the BIOS chips, reflash the chips, solder them back.
