I just built a new rig, with z590 mobo, i5 11400, and Asus RTX 2060 graphics card. I chose 11400 instead of 11400F just because it has UHD graphics card. I thought in daily usage it can use UHD, like laptops, but when I start a game it can switch to Nvidia.
The problem is, I cannot install UHD driver. It says my pc doesn't match the requirements. Am I doing or thinking something wrong?
Thank you.
On desktop motherboards, the default is to disable the iGFX engine if an add-in graphics card is detected. You need to go into BIOS Setup and change the setting to always enable the iGFX engine.
Hope this helps,
Hope this helps,
Hope this helps,
Hope this helps,
I didn't know that. It worked, thanks for the answer.
