Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Cannot overclock my i7 6700k.
Jump to solution
Every time I try to overclock my i7 6700k my computer just crashes and restarts a few minutes after I turn it on. I turned of restart on system failure and it still just restarts all of the time. Did I get a bad processor? I've tried so many different clock speeds and voltages but nothing works.
i7 6700k
asus z 170-a
asus strix 1080
16 GB ddr4 @ 2133
Accepted Solutions
Community Manager
Hello speecbeen,
Just to clarify, Intel does not actively encourage OC since damage can be caused to the unit while practicing this procedure (which voids the warranty).
With that said, here you can find some things you can do related to this issue.
1. Without OC, run the Intel® Processor Diagnostic Tool (to check health of your CPU, in it fails, please contact us by phone, chat or email to check warranty options available): http://intel.ly/1WgoGzz http://intel.ly/1WgoGzz
2. Are you getting any special error messages while these crashes happen?
3. Are you getting any BSOD error messages?
4. I recommend looking for OC guides online
5. I found this video that could help with the issue: https://www.youtube.com/watch?v=FjIweExETlI https://www.youtube.com/watch?v=FjIweExETlI
*Things to note in the video:
-Note tips when crashes are present
-Note the "test" settings done
-Note recommendations advised on the video
-Check memory recommendations on the video
-Check cooling solution
-Check mobo capabilities
-Check if there is OC software built-in the BIOS
-Check OC software within windows
6. You can also wait for peers at the Intel Communities to provide some feedback to you related to this OC problem
Please check and follow recommendations there and let me know how it goes
In case the Diagnostic tool fails, here you can find contact information: http://intel.ly/29LZ0fn http://intel.ly/29LZ0fn
NOTE: This link (video) is being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
Esteban C
Community Manager
Hello speecbeen,
Esteban C
Community Manager
Hello speecbeen,
I would like to verify, were you able to proceed with my recommendations above?
Esteban C
Community Manager
I returned the processor for another and this one is working a lot better.
Community Manager
Thank you for reporting back, speecbeen
It is great to hear the replaced unit is working fine
In case you require any support in the future, feel free to reach us again.
Esteban C
