Processors
16294 Discussions
Cannot restore Default Profile due to Undervoltage Protection
Platinum
I am trying to restore Default Profile of my 13600k.
I was trying to overclock the cache; to do so, you must set a 'Processor Cache Voltage' value that isn't default when Undervoltage Protection is enabled.
I then set Processor Cache Value to 1.225V, and set my Cache ratio to something like 4.8x.
After some testing (no crashes), I want to set back my Processor Cache Value to Default, and when I tried to Save, it gave me an error (attached).
Now I don't know how to set it back to default.
Edit: I restarted my PC which actually automatically reset my BIOS as well, then I was able to reset this setting. However, once it's changed again in XTU, it (Processor Cache Voltage) cannot be returned back to default!
RandyT_Intel
Hi Platinum,
I just want to set proper expectations that overclocking may void the warranty of the processor. Regarding the main issue, if you are unable to reset the default values of the Intel® Extreme Tuning Utility (Intel® XTU), we must follow the steps outlined in this article. The default settings of Intel® XTU are found on the board's BIOS therefore If a profile is set from the Intel® XTU with a specific value, follow the steps below:
  1. Back up any Intel® XTU profile before reinstalling the program to avoid losing settings.
  2. Reinstall Intel® XTU.
  3. Load BIOS default to apply the default settings in the motherboard/system.
I also provide an article for more information. Let me know if you need more details. I'm here to help.
How to Reset the Intel® Extreme Tuning Utility to the Default Settings
What Is Undervolt Protection and How Does It Affect Overclocking in...
Best,
Randy T.
RandyT_Intel
Hi Platinum,
I'm following up on the previous recommendation I provided. Have you had a chance to review the information and apply it to your system? Please let me know the outcome so I can determine the next best course of action.
Best,
Randy T.
Platinum
Hi Randy, thanks for the reply.
I was able to restore the default values via BIOS but I think there is a software issue with XTU. That is you cannot reset the Processor Cache Value via the UI as described. This creates a poor user experience and the described scenario does not sound like a desired behaviour.
RandyT_Intel
Hi Platinum,
Let me coordinate these findings internally and attempt to replicate the issue on my end. Could I please request the SSU log report to gain an overview of the system configuration for simulation purposes. In addition, may I know the version of the XTU you are using and have you tried to set it before without any issues?
Best,
Randy T.
Platinum
Attached SSU Logs and XTU version is 7.14.2.14. Thanks
RandyT_Intel
Hi Platinum,
I just wanted to check in with you about my previous message regarding your inquiry. Have you had a chance to take a look at it? If there's anything you're unsure about or if you need more information, please feel free to reach out. I'm here to help and would be more than happy to assist with any questions you might have!
Best,
Randy T.
RandyT_Intel
Hi Platinum,
Thank you for providing the requested information. I will coordinate internally and get back to you once I have the findings.
Best,
Randy T.
