Ho montato il processore Celeron N4100 su Notebook Teclast F7 Plus. Vorrei incrementare la velocità del processore, da 1.1 a 2.4 GHz. Come faccio? Devo intervenire su BIOS ? Comunque per incrementare un po' le prestazioni, come posso fare?? Grazie anticipatamente per l'aiuto.
Hello Teclast F7 Plus,
Burst Frequency is the maximum single-core frequency at which the processor is capable of operating, and it is an embedded technology in the processor. It is dynamically enabled for short periods of time when needed.
There are no user, operating system, or BIOS settings available to enable/disable this technology. By design, this should save energy and prevent the processor from overheating when at idle or under light workload.
There are a number of factors that may cause the processor not to run at higher speeds including temperature, type of workload, power consumption, environment, platform design, etc.
It is worth noting that if the processor operates at the published base frequency, then it is working under design specifications.
Note: Our support is only provided in English. We may not be able to translate screenshots attached to the thread. To better assist you, we use a translation tool embedded on this Intel® Community.
Wanner G.
If you need further assistance, please let us know. We will be glad to assist you.
Wanner G.
A Contingent Worker at Intel
We have not heard back from you, so we will close this inquiry. If you need further assistance, please post a new question.
Wanner G.
