Hello All,
I am kind of a stranger to computer technologies. Therefore I need your expertise. I have an old notebook with uses i5-3317U processor and I am thinking to renew it to improve computer performance.
I have made couple of searches and found that Intel website shows compatible products under my product's details:
There are several i7 chipsets but not an exact product model name. So, can I change my process with a better one and which processor model should I use?
Thanks in advance.
Before you can do anything, you need to ask the device/motherboard manufacturer which processors are supported by THEIR bios. Then, you can select from those.
An upgrade processor must be socket, chipset, AND BIOS compatible.
https://www.intel.com/content/www/us/en/support/articles/000005682/processors.html
However, none of this matters because your existing processor is soldered to the motherboard.
Doc
Time to get a new(er) laptop.
Doc
Yes, it is easy to say if you are not aware of prices in my country š I will choose other way, I will buy another RAM and will use this old friend until it burst into flames š„
