Buenas tengo un problema y es que he actualizado el procesador del 12700 kf al 14900 kf y en este ultimo hace ruido eléctrico (coil whine) a que puede ser debido? Como solucionarlo? La placa base es nueva Aorus elite ddr4 z790 y la fuente de alimentacion 1000w platinum.
It is not the processor that is making the noise.
[If you find any Intel driver you might need, download and save it now.]
Either one, or some card on the board. Or, do you have any hdd?
it was the cooler (artic freezer 3 280mm, now i got 420mm works bit better, my old corsair aio dont make noise at all but its old and small ) i think the problem was bigger but aio dont care too much.
