Hola. Tengo una lantop de la marca Acer y quiero cambiar el micro procesador dañado. He abierto el portatil y no veo que el procesador este sujeto por algun sistema o tornillo. Querria saber como va fijado el micro SR170 (Intel Core i5-4200U) a la placa madre. Si va pegado con algún fijador o viene de fábrica soldado...?
Gracias
Hi. I have a lantop from the Acer brand and I want to change the damaged micro processor. I have opened the laptop and I do not see that the processor is held by any system or screw. I would like to know how the SR170 (Intel Core i5-4200U) is attached to the motherboard. If it is stuck with a fixative or comes from the factory soldier ...?
Thank you
https://movilesportatiles.com/es/placa-base-sony-vaio-sve14a-1p-0127500-8010-intel-motherboard-repue... https://movilesportatiles.com/es/placa-base-sony-vaio-sve14a-1p-0127500-8010-intel-motherboard-repue...
Your processor is soldered to the motherboard.
/create-advanced-comment.jspa?id=566943&draftID=556786 https://communities.intel.com/create-advanced-comment.jspa?id=566943&draftID=556786
For any repair, contact the laptop manufacturer or a reputable service shop and have the motherboard (with processor) replaced, if it is worth the cost and effort.
Doc
Doc
I thought I could replace the processor ... the i5 is now useless. Thank you very much for answering
